Add Display change action
dkharrin
Post by dkharrin »
Need to have a ACTION not a trigger that waits for a change in display. The time function pause will allow you to put a set time to wait in a task but there are process that their time vary greatly and the window name stay the same. When the screen display changes after being populated with new info it would trigger the task to go to next step.
Re: Add Display change action
When the screen display changes after being populated with new info it would trigger...
What is "new info"? The changes of some window contents?
