Open SFTP Issues
TeamGolden
Open SFTP Issues
Post by TeamGolden »
When opening an SFTP connection in a task I get the error message "Can't open SFTP session. Using keyboard-interactive authentication. Password for username@ftp: Timeout is over." Is Robotask not able to fill in the password? When using PSFTP.exe, I am able to login without an problem once the password has been entered. Can anyone suggest what I'm doing wrong?
Re: Open SFTP Issues
What SSH server do you use?
Could you please send the screenshot of PSFTP after manual login in PSFTP. You can send it to my private email: oleg@robotask.com
I need these strings (see my screenshot):
Also send the complete log-file of the task, please
TeamGolden
The response from the server asked for the password differently and the Open SFTP action did not pick up on it. It asked "Password for username@server:" instead of "username@server's password:". This has been fixed in release 6.5.
