Where can I go to learn Robotask Coding?
umtek12
Post by umtek12 »
1. Where can I learn the coding syntax?
2. Where/What do I do to insert my new code?
3. Is there a Basic for Robotask v6.3? If so, where can I download it?
Re: Where can I go to learn Robotask Coding?
No coding. Only interactive editing of tasks and parameters of each step. RoboTask saves the task into text file similar to INI file.
You can export the task into separate file or import the task file into RoboTask
Use menu Task->Export and Task-Import (see screenshot)
Open the task in task editor and add or edit/remove necessary steps
RoboTask ver 6.3 already contains Script Tools plugin with Java-script and Basic-script actions
You can download additional BASIC plugin for RoboTask 6.3 here: http://www.robotask.com/downloads/oldve ... boTask.zip
