HTML2PDF with RoboTask
eha
Post by eha »
I have about 10'000 htm(l) files and I'd like to convert all of them to pdf. As this doesn't make fun, I found RoboTask, so perhaps you can help me finding a solution.
My plan is the following:
- I put all html files into a certain folder and start the RoboTask-Task ;)
- It shall open the html file with Google Chrome, execute the following keystroke (in order to print the document):
1. STRG + P
2. ENTER
3. ENTER
I already fail in the point to open files automatically with a certain file extension (.htm).
Can you help me?
OS = Windows 7
Google Chrome Version 45.0.2454.85 m
Thanks!
Re: HTML2PDF with RoboTask
Look at the example below
Pay attention that Chrome must be a default browser and default application for HTML files.
CatID=INTEGER|317955339
ExternalName=STRING|"Task102"
ID=INTEGER|2038905681
Name=STRING|"Print HTML files to PDF"
Name=STRING|"File Loop"
date1=STRING|"20150916"
date2=STRING|"20150916"
destvar=STRING|"FILE"
DuringMinutes=STRING|"1"
file0=STRING|"d:\incoming\*.html"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Run ""{file} """
ifnonzero=STRING|"0"
program=STRING|"{file}"
runas=STRING|"0"
wait=STRING|"0"
Name=STRING|"Delay 2 sec"
delay=STRING|"2"
dimension=STRING|"1"
currentwindow=STRING|"1"
fixedwindow=STRING|"0"
keylayout=STRING|"0"
keys=STRING|"""^(P){DELAY 500}{Enter}{DELAY 500}{Enter}{DELAY 500}%({F4})"""
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
