comma-text conversion
rgonzalez
Post by rgonzalez »
Hello, I'm using Windows 10 (just upgraded) and Office 2013 and I'm having a problem trying to use a Comma-text conversion since robotask takes spaces as delimiters if they are not enclosed by quotes.
This is an example of a file that I want to export to csv from excel 2013
This is the file opened in notepad
Theres no quotes added to columns with spaces, this didn't happen when I was using Windows 7 and Office 2013.
And my list separator on regional options is the same as before (a comma)
Is there a way to tell robotask not to take spaces as list separator or a way to force excel to add quotes to columns with spaces?
Thank you.
Re: comma-text conversion
You can convert your string to standard comma-separated string by using Delimit variable action
Also see my example:
CatID=INTEGER|379259420
ExternalName=STRING|"Task10"
ID=INTEGER|15394252
Name=STRING|"Convert to standard comma separated"
Name=STRING|"Set variable ""TEXT"" with value ""rafa rafa,123,rafa rafa rafa,456,""rafa,rafa"""""
varname=STRING|"TEXT"
varvalue=STRING|"rafa rafa,123,rafa rafa rafa,456,""rafa,rafa"""
Name=STRING|"Show ""{text}"""
msg0=STRING|"{text}"
msg1=STRING|"********************"
msg2=STRING|"{text(0)}"
msg3=STRING|"{text(1)}"
msg4=STRING|"{text(2)}"
msg5=STRING|"{text(4)}"
msg6=STRING|"{text(5)}"
msgcount=STRING|"7"
colon=STRING|"0"
comma=STRING|"1"
other=STRING|"0"
quote=STRING|"0"
semocolon=STRING|"0"
space=STRING|"0"
spaceasone=STRING|"0"
string=STRING|"{text}"
tab=STRING|"0"
variable=STRING|"text"
msg1=STRING|"*****************"
msgcount=STRING|"7"
rgonzalez
Post by rgonzalez »
Thank you! This works great! :roll:
