Copying files using excel speadsheet
DSTP
Post by DSTP »
Hi Oleg,
I'm currently stuck on a little project.
I'm wanting to transfer files from one folder to another using excel with a list of codes, I've tried recording a macro for the whole process:
click excel spreadsheet
press enter
Ctrl+C
Click Folder
Click Search Bar
Ctrl+V
Move to Object
At this point it crashes each time, I've changed from icons, to list and even details.
Secondly I've tried building the task:
Open Excel File
However I don't know how to select a cell in the tasks and use this information to find a file from a folder and copy to new folder.
Please help.
Thanks in advance.
Excel File location: C:\Users\Home\Pictures\New folder\Pams Image List
Old File Location: C:\Users\Home\Dropbox\Pams Images
New File Location: C:\Users\Home\Pictures\New folder\
DSTP
Re: Copying files using excel speadsheet
Post by DSTP »
I've managed to build a task, but struggling to use the data in excel.
I: 17/08/2015 19:19:13: Executing "5.Excel Get Cells"
W: 17/08/2015 19:19:13: (2) OLE error 800A03EC
E: 17/08/2015 19:19:13: OLE error 800A03EC
E: 17/08/2015 19:19:13: An error occurred. Step #5 (Excel Get Cells).
E: 17/08/2015 19:19:13: Task execution is aborted
Task as is now:
Excel Open Document
Create Local Variable "ROW" with value "1"
While Loop
Increment Variable "row"
Excel Get Cells
If Then
Copy move File
End If
End Loop
Unfortunately I can say nothing without your task and your Excel document
Also send the full log file of the task.
Pack these files and send the to me to oleg(at)robotask.com
