JS Script variables
rgonzalez
JS Script variables
Post by rgonzalez »
How can I set a var in javascript that I can use later in robotask?
Example:
if("{lenel_pte}" < 0 || "{lenel_central}" < 0)
//RoboTaskApp.SetUserVariable("ping_error", "true")
ping_error = "true";
How to set ping_error to true or some value and then have robotask to read it? I'm doing this with JS Script since there's no IF with OR or AND
Thank you!
Re: JS Script variables
To get variable value use ExpandText method of RoboTaskApp.
for example:
pte = RoboTaskApp().ExpandText('{Lenel_pte}');
To set the value use SetUserVariable method
See my example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
CatID=INTEGER|1416408852
ExternalName=STRING|"Task22"
ID=INTEGER|2117372526
Name=STRING|"Get and Set variables in JS"
Name=STRING|"Create local variable ""LENEL_PTE"" with value ""-1"""
varname=STRING|"LENEL_PTE"
varvalue=STRING|"-1"
Name=STRING|"Create local variable ""LENEL_CENTRAL"" with value ""50"""
varname=STRING|"LENEL_CENTRAL"
varvalue=STRING|"50"
ActionID=STRING|"A_SCRIPT_JSSCRIPT"
Name=STRING|"JS script"
expandvars=STRING|"0"
line00000000=STRING|"pte = RoboTaskApp().ExpandText('{Lenel_pte}');"
line00000001=STRING|"central = RoboTaskApp().ExpandText('{Lenel_Central}');"
line00000003=STRING|"LogMessage(pte);"
line00000004=STRING|"LogMessage(central);"
line00000006=STRING|"if ((pte<0) || (central<0))"
line00000007=STRING|"  {"
line00000008=STRING|"    RoboTaskApp().SetUserVariable('ping_error','True');"
line00000009=STRING|"  }"
line0000000A=STRING|"  else"
line0000000B=STRING|"  {"
line0000000C=STRING|"    RoboTaskApp().SetUserVariable('ping_error','False');"
line0000000D=STRING|"  }"
linecount=STRING|"17"
savescript=STRING|"0"
Name=STRING|"Show ""Lenel_PTE = {Lenel_PTE}"""
msg0=STRING|"Lenel_PTE = {Lenel_PTE}"
msg1=STRING|"Lenel_Central = {Lenel_Central}"
msg2=STRING|"Ping_Error = {Ping_Error}"
msgcount=STRING|"3"
rgonzalez
Post by rgonzalez »
Thank you! :D
