Suggestion ;)
marcolobaido
Suggestion ;)
Post by marcolobaido »
Sometimes I move accidentally the mouse while robotask is working and....IT'S A TRAGEDY :)
What do you think to add a step "BLOCK MOUSE" and "UNBLOCK MOUSE" with the possibility, if you want, to unblock it with a key combination or something like that? What do you think about it?
Re: Suggestion ;)
Thank you for the suggestion. We will investigate the problem.
