Excel Open Document
m1ngle
Excel Open Document
Post by m1ngle »
Hello;
I'm stymied by a simple question. When I run the task "Excel Open document", it does not seem to do anything. The output window tells me the file has been opened successfully, but the file does not appear. I have checked and unchecked the "Hide Excel application" check box. When the box is unchecked, I briefly see the file open and then close. When it is checked, I do not see anything happen. I am not sure what I am missing here. Apologies for the basic question.
Re: Excel Open Document
You will see nothing if you create the task with only one step (Excel Open Document)
When the task has finished RoboTask closes opened document.
You have to do something with opened documents:
- read cells
- write cells
- save document
- something others.
m1ngle
Post by m1ngle »
Thank you again for your help. I'm trying to save the first worksheet only of a workbook and convert it to CSV. I can do this using a macro and keyboard shortcuts, but the workbook needs to be open when I run commands:
Open Excel Document
Send keys to current window
It appears to run successfully but there is no change in the document.
Open Excel Document
In this case use Run Program/Open Document action
then - some pause
Send your keystroke to active window
See the example below. It opens the Excel document and send keystrokes Alt-F and A keys ("save as" operation)
CatID=INTEGER|1639840329
ExternalName=STRING|"Task1291"
ID=INTEGER|1382335971
Name=STRING|"Open Excel doc and send keystroke"
Name=STRING|"Run ""MyFile.xls """
ifnonzero=STRING|"0"
program=STRING|"C:\orders\MyFile.xls"
runas=STRING|"0"
wait=STRING|"0"
Name=STRING|"Delay 1 sec"
delay=STRING|"1"
dimension=STRING|"1"
currentwindow=STRING|"1"
fixedwindow=STRING|"0"
keylayout=STRING|"0"
keys=STRING|"%(F)A"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
