Extract Wildcards
m1ngle
Extract Wildcards
Post by m1ngle »
Hello;
I am having trouble extracting a file using a wildcard in the name. The support documentation says that it is supported, but I am failing every time.
When I use C:\Users\mingle\Documents\3186\3186_0515_Send.zip in the File to Unzip line, the task works fine.
When I use C:\Users\mingle\Documents\3186\3186_*.zip it does not.
Do you have any idea how to make it general?
Thanks
Matt
Re: Extract Wildcards
You can do this by using File Loop.
Look at the example below:
CatID=INTEGER|317955339
ExternalName=STRING|"Task1286"
ID=INTEGER|715768603
Name=STRING|"Extract files by mask"
Name=STRING|"File Loop"
date1=STRING|"20150708"
date2=STRING|"20150708"
destvar=STRING|"ZIPFILE"
DuringMinutes=STRING|"1"
file0=STRING|"C:\Users\mingle\Documents\3186\3186_*.zip"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
ActionID=STRING|"A_ZIP_EXTRACT"
Name=STRING|"Extract Files"
destdir=STRING|"{TempDir}\uzipped\{ZIPfile}"
filetounzip=STRING|"{ZIPfile}"
overwrite=STRING|"0"
password=STRING|"2540125970251992571416055"
passwordmode=STRING|"0"
skipolderfiles=STRING|"0"
unzipfiles=STRING|"*.*"
usefoldernames=STRING|"1"
m1ngle
Post by m1ngle »
Hello Oleg;
Thanks for the solution. It worked great. I only needed to change the destination folder and all files extracted correctly.
