Mail Object
marcolobaido
Mail Object
Post by marcolobaido »
Hi everybody,
can robotask check mails containing the word "POS" into the object and download the attached files in a folder named with the sender email addres ?
i hope my request is clear :)
Re: Mail Object
Look at this example
CatID=INTEGER|317955339
ExternalName=STRING|"Task1285"
ID=INTEGER|1172455680
Name=STRING|"Check email and save attachment"
ActionID=STRING|"A_IMAP_OPEN"
Name=STRING|"IMAP Open"
folder=STRING|"INBOX"
host=STRING|"imap.yourserver.com"
password=STRING|"46696457714449445245462874500319392"
passwordmode=STRING|"0"
port=STRING|"993"
SSL=STRING|"1"
user=STRING|"username"
ActionID=STRING|"A_IMAP_LOOP"
Name=STRING|"IMAP Mail loop"
from=STRING|"from"
number=STRING|"num"
subj=STRING|"subj"
usecc=STRING|"0"
usedate=STRING|"0"
useflags=STRING|"0"
usefrom=STRING|"1"
usesize=STRING|"0"
usesubj=STRING|"1"
useto=STRING|"0"
operator=STRING|"6"
value1=STRING|"POS"
value2=STRING|"{subj}"
ActionID=STRING|"A_IMAP_DOWNLOAD"
Name=STRING|"IMAP Download Message"
attachfolder=STRING|"{TempDir}\msg\{AddressOnly({from})}"
extract=STRING|"1"
num=STRING|"{num}"
overwrite=STRING|"0"
savefilenames=STRING|"0"
savetofile=STRING|"{TempDir}\msg\{Year}{MonthNo}{Day}{Hours}{Minutes}{Seconds}{mSeconds}.eml"
This example demonstrates how to download message by criteria and save attachment into desired folder
marcolobaido
Re: Mail Object
Thanks, it works :) but sometimes the tasks stops because of the error: "Timeout error occurred" during the step "IMAP download message"...how can I bypass the timeout?
Re: Mail Object
What is the size of the message?
marcolobaido
Re: Mail Object
there are 4 attached files:
2.5 MB
48.6 KB
1.9 MB
48.6 KB
marcolobaido
Re: Mail Object
I deleted that mail and it seemed to be ok, but after 20 downloads the timeout error occured during the step "IMAP mail loop", not during the download...isn't it strange?
Re: Mail Object
We will investigate this.
Now you can try to use POP3. RoboTas has similar actions for POP3 protocol
marcolobaido
Re: Mail Object
It works perfectly with POP3 ;)
