Robotask errors out when reaches the login prompt
muneer2908
Post by muneer2908 »
HI,
I want to be able to automatically logged on to my gmail account to send emails.
I am creating a macro for this. When Robotask reaches the login screen, it does not proceed further and stops with error.
How can i make this possible for Robotask to proceed with login in a Macro.
Any suggestions ?
Regards,
Muneer.
Re: Robotask errors out when reaches the login prompt
You can send email from RoboTask directly.
Use Send Email action.
fo Gmail SMTP you have to use these parameters (see screenshot):
muneer2908
Thanks for your reply.
Actually I have another task. There is an inhouse application its link is embedded on the home page of our organization. When we click the link, it opens a "Windows Security" pop up window in which we need to put the domain id (Windows login) and password. There is also a "Remember Password" checkbox on this window. We just click on the "login" button and proceeds to the application to use it.
I created a macro covering the whole process but when I ran the Macro, it stops with error at this login window.
Please suggest what could I do.
Thanks,
Muneer.
I'm sorry I can't see your image. It seems that something is wrong ...
I think that you have to put some pause after starting of application (because the login prompt appear some later) 0.5 - 2 sec. You should determine the optimal pause yourself.
Next, you should send {Enter} key to current window. (see Send Keystrokes action)
