Attaching a file using a variable
marcolobaido
Post by marcolobaido »
Hi everybody,
Can I associate a file to a variable and attack it in a mail? (using Send Mail).
Re: Attaching a file using a variable
Yes, of course. Just put the file name into variable (suppose MyVar = D:\Temp\myfile.zip)
Next, put the expression {MyVar} into "Attachments" field (see screenshot)
If you want to attach several files you have to put into variable all filenames as multiline text: one file name per line.
For example:
D:\Temp\myfile.zip
D:\Temp\myText.txt
marcolobaido
I love Robotask!!!
marcolobaido
Thanks for your fast support!!! :)
