Random Delay
vbigdeli
Random Delay
Post by vbigdeli »
Hi all.
I need Random delay..the current delay action does not accepts variables,so there is no way to put the system/RoboTask on random delay.
The current way is to add a Send Keystrokes and add a delay and then replace the default ms(100) with a random number.
Thanks.
Re: Random Delay
You can make the random delay with using simple algoritm.
See the example below. This task makes random delay from 0.1s to 10s
CatID=INTEGER|2099193306
ExternalName=STRING|"Task1253"
ID=INTEGER|1895035746
Name=STRING|"Random delay"
ToLog=INTEGER|2
message=STRING|"start delay"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"{RandomValue(100)}"
Name=STRING|"Delay 100 ms"
delay=STRING|"100"
dimension=STRING|"0"
message=STRING|"Stop dalay"
