File Loop: multiple paths in variable?
userXXX
Post by userXXX »
Hello Oleg,
I'm trying to fill a variable with several paths to use as the search criteria in a file loop.
I created an example to show my problem (sorry, but upload didn't work):
CatID=INTEGER|740980707
ExternalName=STRING|"Task10"
ID=INTEGER|848860033
LocalVariables=STRING|"L_FILE=,L_PATH_ALL=,L_PATH_COLLECT1=C:\RoboTask\collect1,L_PATH_COLLECT2=C:\RoboTask\collect2,L_PATH1=C:\RoboTask\test1,L_PATH2=C:\RoboTask\test2"
Name=STRING|"Test ""File Loop"""
Name=STRING|"//This works fine"
comment=STRING|"This works fine"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"{L_PATH_COLLECT2}"
f_count=STRING|"1"
file0=STRING|"{L_FILE}"
hidden=STRING|"0"
ifexists=STRING|"0"
move=STRING|"0"
subdir=STRING|"0"
system=STRING|"0"
Name=STRING|"Show ""Check {L_PATH_COLLECT2} !"""
[Actions\Action12\Params]
msg0=STRING|"Check {L_PATH_COLLECT2} !"
Name=STRING|"File Loop"
date1=STRING|"20150512"
date2=STRING|"20150512"
destvar=STRING|"L_FILE"
DuringMinutes=STRING|"1"
file0=STRING|"{L_PATH1}\*.txt"
file1=STRING|"{L_PATH2}\*.txt"
filecount=STRING|"2"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
destdir=STRING|"{L_PATH_COLLECT1}"
f_count=STRING|"1"
hidden=STRING|"0"
ifexists=STRING|"0"
move=STRING|"0"
subdir=STRING|"0"
system=STRING|"0"
Name=STRING|"Show ""Check {L_PATH_COLLECT1} !"""
msg0=STRING|"Check {L_PATH_COLLECT1} !"
Name=STRING|"//This doesn't work"
comment=STRING|"This doesn't work"
Name=STRING|"Set variable ""L_PATH_ALL"" with value ""{L_PATH1}\*.txt{EOL}{L_PATH2}\*.txt"""
varname=STRING|"L_PATH_ALL"
varvalue=STRING|"{L_PATH1}\*.txt{EOL}{L_PATH2}\*.txt"
Enabled=INTEGER|0
Name=STRING|"Show ""{L_PATH_ALL}"""
msg0=STRING|"{L_PATH_ALL}"
file0=STRING|"{L_PATH_ALL}"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
Thank you!
Re: File Loop: multiple paths in variable?
Hm-m... It seems this is malfunction.
We'll correct this. Thank you for your report
You can download fresh copy: http://www.robotask.com/downloads/RobotaskSetup.exe
We have fixed the problem, you can test it.
