Data Extraction POST method
rice1973
Post by rice1973 »
Hi Oleg,
Is data extraction possible by Robotask by any method described in manual;
http://v-count.com/upload/Vapi-EN.pdf
Robotask rules! :)
Re: Data Extraction POST method
Unfortunately POST method is not implemented as yet.
But you can parse any XML data by using XML actions
rice1973
Post by rice1973 »
Ok,
Can i use XML actions to fetch this data?
If yes can you help me setup?
Robotask rules! :)
You must already have the XML file (or XML data in some variable) to use XML actions.
