"It Then" not working after update
rice1973
Post by rice1973 »
Hi Oleg,
The conditions in the task below don't work anymore after update.
So when sunday is <= 8 days from begin of month an => 23 day of the month the task "__Stock.csv__" must run.
But it also runned on 10 day (sunday 10-5)
CatID=INTEGER|1431715566
ExternalName=STRING|"Task32"
ID=INTEGER|90973483
Name=STRING|"koopzondag stock 1e en laatste koopzondag shedule"
operator=STRING|"4"
value1=STRING|"{Day}"
value2=STRING|"8"
Name=STRING|"Start Task ""__Stock.csv__"""
parametercount=STRING|"0"
taskid=STRING|"912874162"
wait=STRING|"1"
operator=STRING|"2"
value2=STRING|"23"
wait=STRING|"1"
Event2=FOLDER
UnigueID=INTEGER|56272592
periodicity=STRING|"1"
periodparameter=STRING|"1000000"
startdate=STRING|"41399"
time0=STRING|"43534000"
time1=STRING|"47100000"
time2=STRING|"50700000"
time3=STRING|"54300000"
time4=STRING|"57900000"
time5=STRING|"61500000"
time6=STRING|"62400000"
timecount=STRING|"7"
wakeup=STRING|"0"
[Events\Event2]
Enabled=INTEGER|0
UnigueID=INTEGER|156025874
[Events\Event2\Params]
id=STRING|"UH6G1CTU"
periodicity=STRING|"2"
periodparameter=STRING|"00000000000000000000001000000000"
startdate=STRING|"41612"
time0=STRING|"47100000"
time1=STRING|"50700000"
time2=STRING|"54300000"
time3=STRING|"57900000"
time4=STRING|"61500000"
time5=STRING|"65100000"
timecount=STRING|"6"
Robotask rules! :)
Re: "It Then" not working after update
You have to compare days AS NUMBERS
See screenshot
You configured the comparison "As String"
The string "8" is greater than string "23". But number 8 is less than number 23
rice1973
Post by rice1973 »
Thank you!
Robotask rules! :)
