wait for command
vbigdeli
wait for command
Post by vbigdeli »
Hi.
I know there is trigger event to run an action when the robotask received a command but please add wait for command action which helps server to get results from client or guest computer .something like results to being reported ..
I am currently using text file to get results and added 1 second delay on server to wait for processing and I don't know what time should I add while I don't know how much should I wait for a task to be done on guest..
Or wait for remote task..
Sorry for my bad English.
Thanks.
vbigdeli
Re: wait for command
Post by vbigdeli »
I'm Sorry.please move this thread to Suggestions.
I wrote this into our ToDo. Maybe we can work something out.
Thank you.
vbigdeli
Post by vbigdeli »
You can also add start a remote task action with the same features that already added to start a task like wait for finish which is not related to listener event.
Thanks Oleg :)
