Renaming Files Automation
DSTP
Post by DSTP »
I'm wanting to automate a process of renaming approx 9000 files.
The new & old file names are stored in a excel spreadsheet and I'd like robotask to find old file name and rename the relevant file from the spreadsheet.
Is this possible?
How would I go about doing this, I'm kinda computer savvy but struggling finding a step by step guide.
Any help would be appreciated.
Thanks in advance.
Chris
Re: Renaming Files Automation
I think yes. You can do this in the loop.
But I want to see the EXCEL file to say more details. Maybe I can create the small example
DSTP
Post by DSTP »
If you could create a small example that would be appreciated..
The forum won't allow me to upload xls files, could you send me an email address
Cheers
Yes, send the file to me (oleg (at) robotask.com )
BTW: now you can attach files in the forum. Use ZIP archive please.
DSTP
Post by DSTP »
Zipped it!
Robotask.zip
(6.99 KiB) Downloaded 1617 times
Describe in more detail, please. I understood so:
- old filename is the file in some subfolder;
- new filename should have the same extension;
- new file is in the same folder as original;
Is this correct?
DSTP
Post by DSTP »
Thats correct.
See this example (below)
Specify correct base folder (step #1)
Specify correct filename of Excel file (step #2)
it should work
CatID=INTEGER|1416408852
ExternalName=STRING|"Task9"
ID=INTEGER|263140533
Name=STRING|"Example for Excel"
Action14=FOLDER
Name=STRING|"Change Folder (c:\basefolder)"
folder=STRING|"c:\basefolder"
Name=STRING|"Break"
Enabled=INTEGER|0
Name=STRING|"Show ""{oldName}"""
[Actions\Action12\Params]
msg0=STRING|"{oldName}"
msg1=STRING|"{newName}"
msgcount=STRING|"2"
Name=STRING|"Rename File"
[Actions\Action13\Params]
file0=STRING|"{OldName}"
ifexists=STRING|"0"
mask=STRING|"{NewName}.*"
subdirs=STRING|"0"
[Actions\Action14]
filename=STRING|"C:\Temp\downloads\Robotask.xlsx"
hide=STRING|"0"
mode=STRING|"0"
Name=STRING|"Create local variable ""ROW"" with value ""1"""
varname=STRING|"ROW"
varvalue=STRING|"1"
Name=STRING|"While loop"
value1=STRING|"true"
Name=STRING|"Increment variable ""row"""
incement=STRING|"1"
vaiable=STRING|"row"
Name=STRING|"Set variable ""OLDCELL"" with value ""R{row}C3"""
varname=STRING|"OLDCELL"
varvalue=STRING|"R{row}C3"
Name=STRING|"Set variable ""NEWCELL"" with value ""R{row}C2"""
varname=STRING|"NEWCELL"
varvalue=STRING|"R{row}C2"
ActionID=STRING|"A_EXCEL_GET"
Name=STRING|"Excel Get Cells"
cell00000000=STRING|"{OldCell}"
cell00000001=STRING|"{newCell}"
count=STRING|"2"
var00000000=STRING|"oldName"
var00000001=STRING|"NewName"
worksheet=STRING|"sheet1"
operator=STRING|"7"
value1=STRING|"{OldName}"
DSTP
Post by DSTP »
Cheers for writing the code.
Where would I place the edited code and how would I get it started.
