Snapshot failure
Helix78
Snapshot failure
Post by Helix78 »
I guess since 6.4 the window snapshot feature or plugin does not work anymore in my Robotask
Before it worked perfectly. The window nade has not changes. I tried to identify the window again. No solution.
>access denied (translated from german)
>WindowSnap failure
Thank you
Re: Snapshot failure
What window do you want to capture? Could you show your task?
You can get such error when you try to capture window of application that require rights elevation. For example REGEDIT.EXE.
This problem can be solved if you run RoboTask "As Administrator" (with rights elevation)
You can use Screenshot action.
1. Focus necessary window
2. Take a screenshot
it works, I have tried this.
See my example below:
CatID=INTEGER|317955339
ExternalName=STRING|"Task1166"
ID=INTEGER|19633302
Name=STRING|"snapshot of RegEdit window"
Name=STRING|"Focus window ""Registry Editor"""
action=STRING|"0"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"0"
classexact=STRING|"0"
exact=STRING|"0"
findmode=STRING|"0"
hidden=STRING|"0"
processall=STRING|"0"
wincaption=STRING|"Registry Editor"
Name=STRING|"Delay 200 ms"
delay=STRING|"200"
dimension=STRING|"0"
ActionID=STRING|"A_SCR_SCREEN"
Name=STRING|"Screenshot"
captureregion=STRING|"0"
filename=STRING|"{TempDir}\tmp.jpg"
format=STRING|"1"
Name=STRING|"Run ""tmp.jpg """
ifnonzero=STRING|"0"
program=STRING|"{TempDir}\tmp.jpg"
runas=STRING|"0"
wait=STRING|"0"
Helix78
Post by Helix78 »
Thank you.
I had to start Robotask as Administrator. This seems to be necessary since 6.4
I can do that but when Robotask starts automatically with windows I have to look how to start it as Adminstrator.
fyi: The main user already has the Administrator role on Windows Server 2012
Starting with Windows Vista the system always reduces the user rights, even the user have administrative rights.
This is new feature of Windows - UAC (User Access Control)
You can turn off it at all (if you need) in control panel. Of course you can start RoboTask "As administrator" mode.
BTW: you can start RoboTask with command line
RoboTask.exe /ADMIN
See mere here about command line options.
