Delete files more older than x days
adorni
Post by adorni »
Is possible to create a task that automatically delete files and folders in specific location, older than xxx days?
Thanks.
Re: Delete files more older than x days
Yes of course. Look at the example named "[DEMO] Clear Temporary Folder"
This task removes files from temporary folder older than 7 days
You can find this task here
You can save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
