utc time to local time
rgonzalez
Post by rgonzalez »
Is there a way to convert UTC datetime to local datetime?
Thank you!
Re: utc time to local time
You can do this with javascript. Use methods of Date object
See the example (task) below:
CatID=INTEGER|317955339
ExternalName=STRING|"Task1144"
ID=INTEGER|33281083
Name=STRING|"JS script..."
ActionID=STRING|"A_SCRIPT_JSSCRIPT"
Name=STRING|"JS script"
expandvars=STRING|"0"
line00000000=STRING|"d = new Date();"
line00000002=STRING|"logmessage('GMT offset= ' + d.getTimezoneOffset() + ' minutes');"
line00000004=STRING|"logmessage('****************');"
line00000006=STRING|"logmessage(d.toGMTString());"
line00000007=STRING|"logmessage(d.toString());"
line00000008=STRING|"logmessage(d.toLocaleString());"
line0000000A=STRING|"logmessage('****************');"
line0000000C=STRING|"d = new Date(2015, 4, 14, 9,0,0);"
line0000000D=STRING|"logmessage(d.toGMTString());"
line0000000E=STRING|"logmessage(d.toString());"
line0000000F=STRING|"logmessage(d.toLocaleString());"
linecount=STRING|"17"
savescript=STRING|"0"
The script is:
d = new Date();
