TWSI
Posts: 22 Joined: Sun Apr 05, 2015 2:01 am
Post
by TWSI » Tue Apr 07, 2015 1:50 pm
I need to assign a variable that will extract an email address from each notepad located at position 1 and place this variable robotask (to) sendemail. I need to include all of this in my current tsk file attached.
Thanks again for the help
David
CatID=INTEGER|210164082
ExternalName=STRING|"Task7"
ID=INTEGER|2093688538
Name=STRING|"Account #000 | Heading"
Name=STRING|"File Loop"
date1=STRING|"20150406"
date2=STRING|"20150406"
destvar=STRING|"BODYTEXT"
DuringMinutes=STRING|"1"
file0=STRING|"C:\sendfile\*.txt"
searchkind=STRING|"0"
sort=STRING|"1"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
ActionID=STRING|"A_FILE_WAIT"
Name=STRING|"Waiting {BodyText} file for 60 sec"
filename=STRING|"{BodyText}"
timeout=STRING|"60"
Name=STRING|"Send Email"
attachcount=STRING|"0"
auth=STRING|"1"
charset=STRING|"iso-8859-1"
from=STRING|"noreplyyahoo.com"
host=STRING|"smtp.gmail.com"
html=STRING|"0"
msg0=STRING|"{TextFile({BodyText})}"
msgcount=STRING|"2"
passwordmode=STRING|"0"
port=STRING|"587"
SSL=STRING|"2"
subject=STRING|"Invoice {ExtractFileNameNoExt({BodyText})} | received today | {DateTime}"
to=STRING|"?????"
user=STRING|"invoicing@gmail.com"
Name=STRING|"Create text file C:\sentfile\sentlog.txt"
encode=STRING|"0"
fileexists=STRING|"1"
filname=STRING|"C:\sentfile\sentlog.txt"
line0=STRING|"{ExtractFileNameNoExt({BodyText})} {DateTime} Sucessfull"
suppress=STRING|"0"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"C:\sentfile\"
f_count=STRING|"2"
file0=STRING|"{BodyText}"
hidden=STRING|"1"
ifexists=STRING|"0"
move=STRING|"1"
rename=STRING|"0"
renamemask=STRING|"*.*.new"
subdir=STRING|"0"
system=STRING|"1"
UnigueID=INTEGER|1121775689
chg=STRING|"1"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"1"
folder1=STRING|"c:\senfile\"
foldercount=STRING|"1"
incmask=STRING|"*.txt"
interval=STRING|"60"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
pass=STRING|"0"
passmode=STRING|"1"
saveresults=STRING|"0"
subfolders1=STRING|"0"
Posts: 3310 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Tue Apr 07, 2015 2:07 pm
I need the example of text.
TWSI
Post
by TWSI » Tue Apr 07, 2015 3:39 pm
please see attached notepad print screen
See attached NOTEPAD.jpg (27.39 KiB) Viewed 17009 times
Post
by Oleg » Tue Apr 07, 2015 4:38 pm
See corrected task below.
Look at the steps #3, #4
Also I have corrected the trigger. You specified incorrect folder name.
CatID=INTEGER|317955339
ExternalName=STRING|"Task1"
sort=STRING|"1"
sortby=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
timeout=STRING|"60"
external=STRING|"1"
linecount=STRING|"0"
linenum=STRING|"1"
variable=STRING|"email"
auth=STRING|"1"
html=STRING|"0"
msgcount=STRING|"2"
port=STRING|"587"
SSL=STRING|"2"
to=STRING|"{email}"
encode=STRING|"0"
suppress=STRING|"0"
f_count=STRING|"2"
hidden=STRING|"1"
ifexists=STRING|"0"
move=STRING|"1"
rename=STRING|"0"
subdir=STRING|"0"
system=STRING|"1"
UnigueID=INTEGER|203047950
chg=STRING|"1"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"1"
folder1=STRING|"c:\sendfile\"
listmode=STRING|"1"
new=STRING|"1"
pass=STRING|"0"
passmode=STRING|"1"
TWSI
Post
by TWSI » Tue Apr 07, 2015 4:49 pm
Oh got it
Thanks again......
David
