Zip files with files datetime
Prolasis
Post by Prolasis »
hello i am having trouble getting my zipped file to use the files datetime instead of the current datetime. Example i have my zip filename to be 2014-08-1 not todays date. Any idea how i can leverage the date time variable from the files i pick
C:\{Year}-{MonthNo}-{Day}-{Hours}-{Minutes}-{ExtractFileName({Source_folder})}.zip
Thanks
Re: Zip files with files datetime
I'm afraid that I don't understand your goal correctly.
Clarify please: do you want to retrieve the date (or year, month and day) from the name of file?
Prolasis
Post by Prolasis »
Hi Yes, Lets say i zip a file from aug 2014. instead of putting the curernt date as the .zip file name i would want the aug date as the file name.
You can do this by using regular expressions. It is shortest way.
See my example below
Save the text of the task into a file and use menu Task->Import to import the task into RoboTask
CatID=INTEGER|317955339
ExternalName=STRING|"Task1144"
ID=INTEGER|766386622
Name=STRING|"Parse file name YYYY-MM-DD.zip"
Name=STRING|"Show ""Parse the file name as format"""
msg0=STRING|"Parse the file name as format"
msg1=STRING|"YYYY-MM-DD.zip"
msg2=STRING|"-or-"
msg3=STRING|"YYYY-M-D.zip"
msgcount=STRING|"4"
Name=STRING|"Text Loop"
destvar=STRING|"FILENAME"
line0=STRING|"2014-08-1.zip"
line1=STRING|"2014-8-15.zip"
line2=STRING|"SumpleName.txt"
linecount=STRING|"3"
sourcetext=STRING|"1"
Name=STRING|"RegExp Match"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{filename}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"(?i)(\d{4})-(\d{1,2})-(\d{1,2})\.zip"
savesubexpression=STRING|"1"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
subexpressionvar=STRING|"found"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"res"
value1=STRING|"{res}"
Name=STRING|"Show ""File name {filename}"""
msg0=STRING|"File name {filename}"
msg2=STRING|"Year = {found(1)}"
msg3=STRING|"Month = {found(2)}"
msg4=STRING|"Day = {found(3)}"
msgcount=STRING|"5"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""Name {filename}"""
icon=STRING|"3"
msg0=STRING|"Name {filename}"
msg1=STRING|"has wrong format!!"
msgcount=STRING|"2"
Prolasis
Post by Prolasis »
thanks Oleg ,
Ill check this out
Prolasis
Post by Prolasis »
Thanks it did work, but now i am trying to zip all my files in separate archives by the month. Example i have 100 files but they are dated from different months. I want to zip all files in june in one archive and rest of the months the same. Any idea
Thanks
