delete a piece of string with wildcards?
pancakegh
Post by pancakegh »
I have a main folder with subfolders wich contain another subfolder with in the last folder a jpg image file named " ***.**.****.jpg " the image files have different names
I need to upload the subfolders in the main folder to my FTP wich has the same structure as the local main folder.
Synchronizing the folders takes WAY to much time because the FTP directory contains an enormous amount of .jpg files already.
I want to individually upload every single image in my local folder to the corresponding FTP folder.
I made a simple file loop wich extracts a variable called " {oldfilename} " for the local image directory. and in the file loop it changes the "{oldfilename}" into "{ftplocatie}" wich will be the ftp directory.
here's an example of the {oldfilename}: C:\Users\webdesign\Desktop\temp\hires\2\401.90.0012.jpg
Here's an example of the {ftplocatie}: \products\hires\2\401.90.0012.jpg
All I need is to trim the " 401.90.0012.jpg " part.
But how do I delete an "X" amount of characters at the end of a string?
I can't seem to find and replace the 401.90.0012.jpg part with wildcards ***.**.****.jpg to nothing.
Here's my task:
CatID=INTEGER|317955339
ExternalName=STRING|"Task13"
ID=INTEGER|426203686
Name=STRING|"File Loop..."
ToLog=INTEGER|0
Name=STRING|"File Loop"
date1=STRING|"20100105"
date2=STRING|"20100105"
destvar=STRING|"OLDFILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"C:\Users\webdesign\Desktop\temp\*.jpg"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos"
from=STRING|"30"
search=STRING|"\"
source=STRING|"{OldFileName}"
variable=STRING|"APos"
ActionID=STRING|"A_STR_DELETE"
Name=STRING|"STR Delete"
amount=STRING|"{APos}"
from=STRING|"1"
variable=STRING|"NewFileName"
ActionID=STRING|"A_STR_INSERT"
Name=STRING|"STR Insert"
insert=STRING|"\products\"
pos=STRING|"1"
source=STRING|"{newfilename}"
variable=STRING|"ftplocatie"
Name=STRING|"Show ""{oldfilename}"""
msg0=STRING|"{oldfilename}"
msg2=STRING|"{ftplocatie}"
msgcount=STRING|"3"
Re: delete a piece of string with wildcards?
Use {ExtractFilePath()} variable.
See my example below. Save the text of task into a file and use menu Task->Import to import into RoboTask.
ExternalName=STRING|"Task1111"
ID=INTEGER|1644715928
Name=STRING|"trim the end"
Name=STRING|"Create local variable ""SOUR"" with value ""\products\hires\2\401.90.0012.jpg"""
varname=STRING|"SOUR"
varvalue=STRING|"\products\hires\2\401.90.0012.jpg"
Name=STRING|"Set variable ""DEST"" with value ""{ExtractFilePath({sour})}\"""
varname=STRING|"DEST"
varvalue=STRING|"{ExtractFilePath({sour})}\"
Name=STRING|"Show ""{sour}"""
msg0=STRING|"{sour}"
msg1=STRING|"{dest}"
msgcount=STRING|"2"
