Regular Expression in Copy/Move
DMolter
Post by DMolter »
Can regular expression be used in copy/move tasks?
I want to move files that are all T{date}.TXT (T20150225.TXT for example), can I define one copy/move task to move all such files?
Re: Regular Expression in Copy/Move
Copy/move action can use only standard mask symbols
  • * - any quantity of of any symbols
    ? - one symbol
If you want to use regular expressions you can process files in the loop and check each name by using RegExp Match
See my example below:
CatID=INTEGER|317955339
ExternalName=STRING|"Task405"
ID=INTEGER|1593129795
Name=STRING|"RegEx in filename"
Name=STRING|"File Loop"
date1=STRING|"20150227"
date2=STRING|"20150227"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"D:\incoming\t*.txt"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"RegExp Match"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{ExtractFileName({filename})}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"(?i)t[0-9]{8}\.txt"
savesubexpression=STRING|"0"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"found"
value1=STRING|"{found}"
Name=STRING|"Show ""File found: {filename}"""
msg0=STRING|"File found: {filename}"
