Copy file from subfolders
mondocane
Post by mondocane »
I have been trying to create a task that will copy all *.mp3 files that are stored in multiple folders and consolidate them to one folder. In the Copy Move command I specify C:\*.mp3 and the destination folder and check the recurse to subfolders option. The task runs for less than a second and doesnt search the subfolders. What am I doing wrong? HELP!!
You can use "Synchronize Folders" action with unidirectional mode.
