Run a program as admin
vbigdeli
Post by vbigdeli »
I don't see run as administrator or normal user in Run program/open document task.
Please add this feature.
Thanks.
Re: Run a program as admin
"Run as administrator" mode is impossible without manual confirmation. This is a very uncomfortable way for automation process
You should run RoboTask "As Administrator" to start another applications without confirmations.
Also you can turn off the UAC in control panel. But pay attention, that this way is not recommended
To run another programs "As Administrator" you can use RG.EXE utility. It is in RoboTask's folder. By default it is here: "C:\Program Files (x86)\RoboTask\RG.exe"
Usage:
RG.exe [/p] <command_line>
/p - RG waits when the command will be finished
It launches your command line with administrative rights.
