Check, if task is running
userXXX
Post by userXXX »
Hello Oleg,
what would be the easiest way to check if a task is running?
Do I have to loop through all tasks like that...
cnt = RoboTaskApp.TaskCount
For i = 0 To cnt - 1
extNam = RoboTaskApp.TaskInfoExtName(i)
Next
...until I find the external task name searching for, get the TaskNum (variable i) and then use TaskInfoState?
Thank you.
Re: Check, if task is running
See the example of VB script
num = RoboTaskApp.TaskNumByExternalName("MyTestTask")
if num >= 0 then
  st = RoboTaskApp.TaskInfoState(num)
  LogMessage(cstr(st))
else
  LogMessage("No such task!!!")
end if
See all methods and properties of RoboTaskApp object here: http://www.robotask.com/help/index.php? ... object.htm
The same example on JavaScript
num = RoboTaskApp().TaskNumByExternalName("MyTestTask");
if (num >= 0)
  st = RoboTaskApp().TaskInfoState(num);
  LogMessage(st);
else
  LogMessage("No such task!!!");
