imap mail loop
rgonzalez
imap mail loop
Post by rgonzalez »
Hello, how can I delete a message at the end of each imap mail loop without breaking the order for the next iteration?
Let's say I have 5 messages, and the imap mail loop takes a var for the message order. After I process each message, I need to delete that message, but in the next iteration the message number changes, so the imap mail loop throws an error.
Also I tried to always parse and delete the message no. 1, but it's not working either.
I don't have any problems if I delete all the messages after the loop is ended, but it's crucial for me to delete each message after being processed individually.
Also imap move message is working as copy message. The window title for that action differs on the name.
Example:
CatID=INTEGER|1881165001
ExternalName=STRING|"Task70"
ID=INTEGER|489364280
Name=STRING|"imap mail loop test"
ToLog=INTEGER|1
ActionID=STRING|"A_IMAP_OPEN"
Name=STRING|"IMAP Open"
folder=STRING|"INBOX"
host=STRING|"test@test.com"
password=STRING|"4540845249455204524945520"
passwordmode=STRING|"0"
port=STRING|"993"
SSL=STRING|"1"
user=STRING|"test@test.com"
ActionID=STRING|"A_IMAP_LOOP"
Name=STRING|"IMAP Mail loop"
flags=STRING|"D"
from=STRING|"from"
number=STRING|"msg_num"
subj=STRING|"subj"
usecc=STRING|"0"
usedate=STRING|"0"
useflags=STRING|"0"
usefrom=STRING|"1"
usesize=STRING|"0"
usesubj=STRING|"1"
useto=STRING|"0"
Name=STRING|"//Do stuff like download and parse locally and then move (copy?) and delete the message"
comment=STRING|"Do stuff like download and parse locally and then move (copy?) and delete the message"
ActionID=STRING|"A_IMAP_MOVE"
Name=STRING|"IMAP Move Message to Folder ""INBOX.Requests"""
folder=STRING|"INBOX.Requests"
msgnum=STRING|"{msg_num}"
parameters=STRING|"test.com,993,1,test@test.com"
ActionID=STRING|"A_IMAP_SETFLAGS"
Name=STRING|"IMAP Set Message Flags"
answered=STRING|"2"
deleted=STRING|"1"
draft=STRING|"2"
flagged=STRING|"2"
recent=STRING|"2"
seen=STRING|"2"
ActionID=STRING|"A_IMAP_PURGE"
Name=STRING|"IMAP Delete Marked Messages"
ActionID=STRING|"A_IMAP_SELETFOLDER"
Name=STRING|"IMAP Select Folder: INBOX"
ActionID=STRING|"A_IMAP_CLOSE"
Name=STRING|"IMAP Close"
Enabled=INTEGER|0
UnigueID=INTEGER|1839787036
id=STRING|"RXWMU1J4"
interval=STRING|"600"
Re: imap mail loop
Move the step "IMAP Delete Marked Messages" out of the loop and remove the step "IMAP Select Folder: INBOX" (it's superfluous)
Also see the corrected task below:
CatID=INTEGER|317955339
ExternalName=STRING|"Task259"
Name=STRING|"imap mail loop test (version 2)"
ToLog=INTEGER|1
port=STRING|"993"
SSL=STRING|"1"
flags=STRING|"D"
from=STRING|"from"
subj=STRING|"subj"
usecc=STRING|"0"
usedate=STRING|"0"
useflags=STRING|"0"
usefrom=STRING|"1"
usesize=STRING|"0"
usesubj=STRING|"1"
useto=STRING|"0"
answered=STRING|"2"
deleted=STRING|"1"
draft=STRING|"2"
flagged=STRING|"2"
recent=STRING|"2"
seen=STRING|"2"
Enabled=INTEGER|0
Enabled=INTEGER|0
UnigueID=INTEGER|861521457
id=STRING|"QH9DW3KP"
rgonzalez
Re: imap mail loop
Post by rgonzalez »
Thanks for your response, I did that before but the messages are deleted at the end of the task. I need to delete each message after each loop. Is there a way to do this? Thank you!
