extracting specific paragrfs from text file
mahirfarook
Post by mahirfarook »
how to extract specific paragraphs from a text file and save it to another new text file...?
Re: extracting specific paragrfs from text file
mahirfarook wrote:how to extract specific paragraphs from a text file and save it to another new text file...?
What criteria? Algorithm may be VERY complex.
See the simple example below. This task processes TXT files in folder D:\incoming
It extracts 1-st line from the text and save it in new file in D:\Dest folder.
Save the task into a file and use menu Task->Import to import it into RoboTask. Next you can see it in task editor of RoboTask.
CatID=INTEGER|317955339
ExternalName=STRING|"Task1242"
ID=INTEGER|597248694
Name=STRING|"extract 1-st line from text"
Name=STRING|"Create local variable ""CNT"" with value ""1"""
varname=STRING|"CNT"
varvalue=STRING|"1"
Name=STRING|"File Loop"
date1=STRING|"20150124"
date2=STRING|"20150124"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"D:\incoming\*.txt"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
external=STRING|"1"
filename=STRING|"{filename}"
linecount=STRING|"0"
linenum=STRING|"1"
variable=STRING|"line"
Name=STRING|"Create text file d:\dest\{cnt}.txt"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"d:\dest\{cnt}.txt"
line0=STRING|"{line}"
suppress=STRING|"1"
Name=STRING|"Increment variable ""cnt"""
incement=STRING|"1"
vaiable=STRING|"cnt"
