It's this query here
https://social.msdn.microsoft.com/forum ... age-by-sql
Now I presume it connects ok as the initial errors were sorted
However the file that gets written is 0K
Run the query locally o nthe detination server runs fine
CatID=INTEGER|0
ExternalName=STRING|"Task10"
ID=INTEGER|1909129044
LocalVariables=STRING|"""SQLPERFORMANCE="""""""""""
Name=STRING|"get vcenter CPU usage"
Name=STRING|"Create local variable ""SQLPERFORMANCE"" with value """""
varname=STRING|"SQLPERFORMANCE"
ActionID=STRING|"A_EXECSQL"
Name=STRING|"SQL Query"
assignvar=STRING|"1"
connectionstring=STRING|"Provider=MSDASQL.1;Persist Security Info=False;Extended Properties=""DSN=VCenter;Description=Vcenter;Trusted_Connection=Yes;APP=RoboTask;WSID=DINGDC;DATABASE=ecm"""
override=STRING|"0"
password=STRING|"2005620872218982164521896"
sql=STRING|"""USE ECM"",""DECLARE @ts_now bigint = (SELECT cpu_ticks/(cpu_ticks/ms_ticks)FROM sys.dm_os_sys_info); "",,""SELECT TOP(512) SQLProcessUtilization AS [SQL Server Process CPU Utilization], "","" SystemIdle AS [System Idle Process], "","" 100 - SystemIdle - SQLProcessUtilization AS [Other Process CPU Utilization],"","" DATEADD(ms, -1 * (@ts_now - [timestamp]), GETDATE()) AS [Event Time]"","" "",""FROM ( "","" SELECT record.value('(./Record/@id)[1]', 'int') AS record_id, "","" record.value('(./Record/SchedulerMonitorEvent/SystemHealth/SystemIdle)[1]', 'int') "","" AS [SystemIdle], "","" record.value('(./Record/SchedulerMonitorEvent/SystemHealth/ProcessUtilization)[1]', "","" 'int') "","" AS [SQLProcessUtilization], [timestamp] "","" FROM ( "","" SELECT [timestamp], CONVERT(xml, record) AS [record] "","" FROM sys.dm_os_ring_buffers "","" WHERE ring_buffer_type = N'RING_BUFFER_SCHEDULER_MONITOR' "","" AND record LIKE '%<SystemHealth>%') AS x "","" ) AS y "",""ORDER BY record_id DESC;"""
timeout=STRING|"120"
varname=STRING|"{SQLPERFORMANCE}"
Name=STRING|"Create text file C:\vcentersql.txt"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"C:\vcentersql.txt"
line0=STRING|"{SQLPERFORMANCE}"
suppress=STRING|"0"
UnigueID=INTEGER|16445953
id=STRING|"3Z3LJ0OD"
periodicity=STRING|"0"
startdate=STRING|"42026"
time0=STRING|"10808000"
time1=STRING|"25208000"
time2=STRING|"39608000"
time3=STRING|"54008000"
time4=STRING|"68408000"
time5=STRING|"82808000"
timecount=STRING|"6"
