Allow CTRL+A in SQL text editor..
breq
Post by breq »
Add the ability to select all text in the SQL box by pressing CTRL+A
For example: if I need to change SQL I need to select it all manually with mouse... with CTRL+A it will be more efficient
Re: Allow CTRL+A in SQL text editor..
Wrote into ToDo, thank you.
