Join text files into one file
vbigdeli
Post by vbigdeli »
I need a plugin to join multiple text files in one directory and join/append them into one file.
I could do it with write text file but it takes alot of time because I had more than 3k text files and the final file would become more than 500MB .
So I need append text file plugin not the write text files which write files from the beginning.
I already used txtcollector software to do it.
I hope to see my suggestions soon or otherwise I have to move to WinAutomation .
Thanks Oleg.
Re: Join text files into one file
I added your suggestion into our ToDo. We'll discuss it.
But pay attention that you can join text files in a folder right now
See the example below:
CatID=INTEGER|317955339
ExternalName=STRING|"Task1170"
ID=INTEGER|1270824523
Name=STRING|"Join TXT file in folder to one file"
Name=STRING|"Create local variable ""TARGETFILE"" with value ""d:\dest\target.txt"""
varname=STRING|"TARGETFILE"
varvalue=STRING|"d:\dest\target.txt"
Name=STRING|"Create local variable ""SOURCEDIR"" with value ""c:\incoming"""
varname=STRING|"SOURCEDIR"
varvalue=STRING|"c:\incoming"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{TargetFile}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
Name=STRING|"Create local variable ""CNT"" with value ""1"""
varname=STRING|"CNT"
varvalue=STRING|"1"
Name=STRING|"File Loop"
date1=STRING|"20150109"
date2=STRING|"20150109"
destvar=STRING|"CURRENTFILE"
DuringMinutes=STRING|"1"
file0=STRING|"{SourceDir}\*.txt"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
message=STRING|"{cnt}; {CurrentFile}"
Name=STRING|"Create text file {TargetFile}"
encode=STRING|"0"
fileexists=STRING|"1"
filname=STRING|"{TargetFile}"
line0=STRING|"*******************"
line1=STRING|"File: {CurrentFile}"
line2=STRING|"*******************"
line3=STRING|"{TextFile({CurrentFile})}"
linecount=STRING|"4"
suppress=STRING|"0"
Name=STRING|"Increment variable ""cnt"""
incement=STRING|"1"
vaiable=STRING|"cnt"
Also see another version of this task. It should work faster
ExternalName=STRING|"Task1206"
ID=INTEGER|18567467
Name=STRING|"Join TXT file in folder to one file (version 2)"
message=STRING|"Writing target file"
[Actions\Action12\Params]
encode=STRING|"0"
line0=STRING|"{Text}"
suppress=STRING|"1"
Name=STRING|"Create local variable ""TEXT"" with value """""
varname=STRING|"TEXT"
Enabled=INTEGER|0
Count=STRING|"1"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
varvalue=STRING|"1"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Set variable ""TEXT"" with value ""{Text}{EOL}*******************{EOL}File: {CurrentF..."""
varvalue=STRING|"{Text}{EOL}*******************{EOL}File: {CurrentFile}{EOL}*******************{EOL}{TextFile({CurrentFile})}"
incement=STRING|"1"
Save the text of the task into a file and use menu Task->Import to import the task into RoboTask.
vbigdeli
Post by vbigdeli »
Oleg,
I have more than 5000 text files and it takes a lot of time with Write text file.it would takes more than 10 mins with a Intel i7 4790k system & samsund SSD 850 Pro.
I need Join text files task to do it much more faster .
Thanks.
I optimized the 2-nd task
Try 3-d version below. I tested it. It processed more than 6000 files in 3 minutes.
I prohibited the expand of nested variables. This brakes the process very mach.
I used the expressions {#Text} and {#TextFile({CurrentFile})}. See steps #9, #14, #20
Of course the speed depends on size of files, but speed was increased.
ID=INTEGER|18567467
Name=STRING|"Join TXT file in folder to one file (version 3)"
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
incement=STRING|"1"
Name=STRING|"Increment variable ""total"""
incement=STRING|"1"
vaiable=STRING|"total"
operator=STRING|"2"
type=STRING|"1"
value1=STRING|"{cnt}"
value2=STRING|"1000"
[Actions\Action13\Params]
[Actions\Action14]
[Actions\Action14\Params]
encode=STRING|"0"
line0=STRING|"{#Text}"
suppress=STRING|"1"
[Actions\Action15]
Name=STRING|"Set variable ""TEXT"" with value """""
[Actions\Action15\Params]
[Actions\Action16]
Name=STRING|"Set variable ""CNT"" with value ""1"""
[Actions\Action16\Params]
varvalue=STRING|"1"
[Actions\Action17]
[Actions\Action18]
[Actions\Action19]
[Actions\Action19\Params]
[Actions\Action20]
[Actions\Action20\Params]
encode=STRING|"0"
suppress=STRING|"1"
Count=STRING|"1"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
varvalue=STRING|"1"
Name=STRING|"Create local variable ""TOTAL"" with value ""1"""
varname=STRING|"TOTAL"
varvalue=STRING|"1"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
message=STRING|"{total}; {CurrentFile}"
Name=STRING|"Set variable ""TEXT"" with value ""{#Text}{EOL}*******************{EOL}File: {Current..."""
varvalue=STRING|"{#Text}{EOL}*******************{EOL}File: {CurrentFile}{EOL}*******************{EOL}{#TextFile({CurrentFile})}"
