SQL count to variable
sforsythe
Post by sforsythe »
I need to check the data in a file to see if it exists in the database and insert the records that don't.
The data is "Date", "Time", and "Temperature" and I need to see if there is already a record in the database for the "Date" and "Time" of each line in the file.
I tried using SQL Query to return a count for records, but don't seem to be able to get it to work. The connection to the database works and I can insert records, but don't understand how to return the results of a select statement (tried using the "assign rows affected into variable").
The simple test I tried was:
create a variable called "VCOUNT" with value 0,
"Select count(*) from table" (the answer should be 671)
assign to {vCount}
The answer is still zero. I've run the query from inside MS Access and it works.
sforsythe
Re: SQL count to variable
Post by sforsythe »
Dataset Loop seems to work (but don't really need a loop) the result is a single value.
Now having problems with variables in the SQL statement.
The insert statement works:
INSERT into Lake_Test(fDate, fTime, fTemperature)
values('{vDate}','{vTime}',{line(3)})
But the select statement returns "data type mismatch in criteria expression"
SELECT
count(*)
FROM
Lake_Test
WHERE
fDate = '{vDate}' AND fTime = '{vTime}'
The database table Lake_Test has 3 fields
fDate = short date (DD/MM/YYYY)
fTime = short time (HH:MM)
fTemperature = double (9999.9)
the variables are and the first line results are:
vDate = 17/12/2014
vTime = 07:35
vline3 = 15.0
Any ideas?
See my example below. It works.
I optimized it for MySQL database.
Pay attention that you specify DATE and TIME values (in WHERE clause) as strings. The acceptable format of these strings can depend on Database kind and your regional settings.
MySQL can accept (independently of regional settings):
  • DATE as 'YYYY-MM-DD'
    TIME as 'hh:mm' or 'hh:mm:ss'
    DATETIME as 'YYYY-MM-DD hh:mm:ss'
CatID=INTEGER|317955339
ExternalName=STRING|"Task259"
ID=INTEGER|326707182
Name=STRING|"Test DB filters"
Name=STRING|"//without filter"
comment=STRING|"without filter"
Name=STRING|"Set variable ""VCOUNT"" with value ""{row(0)}"""
varname=STRING|"VCOUNT"
varvalue=STRING|"{row(0)}"
Name=STRING|"Show ""{vCount}"""
[Actions\Action12\Params]
msg0=STRING|"{vCount}"
Name=STRING|"Dataset Loop"
commatext=STRING|"0"
connectionstring=STRING|"Provider=MSDASQL.1;Persist Security Info=False;Data Source=MySQLtest"
override=STRING|"0"
password=STRING|"2031219857201061985019088"
sql=STRING|"""Select count(*) from temperatures"""
timeout=STRING|"60"
var2=STRING|"ROW"
withmemo=STRING|"0"
Name=STRING|"//with filter"
comment=STRING|"with filter"
Name=STRING|"Set variable ""VDATE"" with value ""2014-12-09"""
varname=STRING|"VDATE"
varvalue=STRING|"2014-12-09"
Name=STRING|"Set variable ""VTIME"" with value ""16:20"""
varname=STRING|"VTIME"
varvalue=STRING|"16:20"
override=STRING|"0"
password=STRING|"2031219857211351959521137"
sql=STRING|"""Select count(*) from temperatures "",""where fdate = '{vdate}' and ftime='{vtime}'"""
timeout=STRING|"60"
var2=STRING|"ROW"
withmemo=STRING|"0"
