Get File DateTime
sforsythe
Get File DateTime
Post by sforsythe »
Is there a way of getting the DateTime of a file? I have to download a file on a remote system that I have no control over and is updated every 30 minutes (the name doesn't change, just new time stamp). When I download the file I want to rename it to include the DateTime (i.e. FILE.CSV would become FILE201412180703.CSV).
sforsythe
Re: Get File DateTime
Post by sforsythe »
Don't need this now. Just renaming from FILE.CSV to FILE{Year}{MonthNo}{Day}{Hours}{Minutes}.CSV. The Timestamp on the file is preserved.
Look at variables FileTime (Files & Folders group) and DateTimeToFormat (Date & Time group)
See format settings here (at the bottom of the page)
Format options for format variables:
d - Displays the day as a number without a leading zero (1-31).
dd - Displays the day as a number with a leading zero (01-31).
mm - Displays the month as a number with a leading zero (01-12). If the mm specifier immediately follows an h or hh specifier, the minute rather than the month is displayed.
yy - Displays the year as a two-digit number (00-99).
yyyy - Displays the year as a four-digit number (0000-9999).
h - Displays the hour without a leading zero (0-23).
hh - Displays the hour with a leading zero (00-23).
n - Displays the minute without a leading zero (0-59).
nn - Displays the minute with a leading zero (00-59).
s - Displays the second without a leading zero (0-59).
ss - Displays the second with a leading zero (00-59).
am/pm - Uses the 12-hour clock for the preceding h or hh specifier, and displays 'am' for any hour before noon, and 'pm' for any hour after noon. The am/pm specifier can use lower, upper, or mixed case, and the result is displayed accordingly.
a/p - Uses the 12-hour clock for the preceding h or hh specifier, and displays 'a' for any hour before noon, and 'p' for any hour after noon. The a/p specifier can use lower, upper, or mixed case, and the result is displayed accordingly.
Also see the example below.
CatID=INTEGER|1416408852
ExternalName=STRING|"Task119"
ID=INTEGER|468440609
Name=STRING|"Show ""File time""..."
Name=STRING|"Create local variable ""FILENAME"" with value ""C:\Temp\108736_2.jpeg"""
varname=STRING|"FILENAME"
varvalue=STRING|"C:\Temp\108736_2.jpeg"
Name=STRING|"Show ""File Name: {FileName} """
msg0=STRING|"File Name: {FileName} "
msg2=STRING|"File time"
msg3=STRING|"{FileTime({FileName})}"
msg5=STRING|"transformed file time:"
msg6=STRING|"{DateTimeToFormat({FileTime({FileName})},yyyy-mm-dd-hh-nn-ss)}"
msgcount=STRING|"7"
