Monitor for colors appearing and use If/then
Steve8G
Post by Steve8G »
How can I make it click on a specific area depending if the color red appear on a specific pixel on the window
Re: Monitor for colors appearing and use If/then
I think yes.
You can check the color pixel periodically and make necessary actions if color corresponds your etalon.
algorithm will be like this
Window pixel
Color Compliance
if result = true then
   do something
end if
See actions:
Steve8G
Post by Steve8G »
Thanks but the complicated part is that it will have to wait for the pixel on the screen to change for the desired color, so it will have to be monitoring the screen all the time to see if the color change, then when it will change for the desired color, it will do the appropriate action
is it possible?
See my example.
This task waits when the color on specified screen pixel will be Blue ($00800000)
Save the text of the task into a file and use menu Task->Import
CatID=INTEGER|317955339
ExternalName=STRING|"Task1111"
ID=INTEGER|1830696294
Name=STRING|"Wait for color"
Name=STRING|"Create local variable ""COLORMATCHED"" with value ""false"""
varname=STRING|"COLORMATCHED"
varvalue=STRING|"false"
Name=STRING|"While loop"
operator=STRING|"1"
value1=STRING|"{ColorMatched}"
ActionID=STRING|"A_SCR_SCRPIXEL"
Name=STRING|"Screen Pixel"
variable=STRING|"color"
x=STRING|"111"
y=STRING|"171"
ActionID=STRING|"A_SCR_COLORCOMPLIANCE"
Name=STRING|"Color Compliance"
color1=STRING|"{color}"
color2=STRING|"$00800000"
tolerance=STRING|"16"
variable=STRING|"ColorMatched"
operator=STRING|"1"
Name=STRING|"Delay 500 ms"
delay=STRING|"500"
dimension=STRING|"0"
Name=STRING|"Show ""Point color is Blue!!!!"""
msg0=STRING|"Point color is Blue!!!!"
