Can i create a trigger - "wait for folder to become empty"
leshemomer
Post by leshemomer »
Can i create a trigger which monitors a certain folder to activate a task when the folder becomes empty?
thanks,
Omer
Re: Can i create a trigger - "wait for folder to become empt
You can attach to the task File monitor trigger.
But you should check the amount of files in the folder in the task. See {FilesCount()} variable.
Algorithm is simple:
if {FilesCount(c:\myfolder)} = 0 then
   do something
end if
Thus, necessary actions will be performed only if the folder is empty.
leshemomer
Thanks! (:
where do I paste it?
could you maybe send a screenshot?
i'm not really sure how to use the IF
Omer
See the example of the task below.
Save the text of the task into a file and use menu Task->Import to import the task into RoboTask.
Do not forget to enable task after importing.
CatID=INTEGER|1416408852
ExternalName=STRING|"Task113"
ID=INTEGER|953625670
Name=STRING|"Start main task if folder is empty"
type=STRING|"1"
value1=STRING|"{FilesCount(c:\incoming)}"
value2=STRING|"0"
Name=STRING|"Start Main Task"
parametercount=STRING|"0"
taskid=STRING|"631126132"
wait=STRING|"0"
UnigueID=INTEGER|16445953
chg=STRING|"1"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"1"
folder1=STRING|"C:\incoming"
foldercount=STRING|"1"
incmask=STRING|"*.*"
interval=STRING|"15"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
pass=STRING|"0"
passmode=STRING|"1"
saveresults=STRING|"0"
subfolders1=STRING|"1"
leshemomer
Wow! That's GREAT
now I understand how it's supposed to be (:
thanks soo sooo much!
Omer
