counting rows and unique numbers
jeroen123
Post by jeroen123 »
Hello Oleg,
I have a simple tekst file of numbers (customerIDnumbers) like:
1225
1225
1309
1388
1388
2820
2820
I want to know how many lines I have; and how many unique numbers; in this case 7 rows, and 4 unique numbers.
so I wrote the following script:
with a íf' statement to compare the customerIDnumber with a 'compare' value.
It seems that this doesnot work; it shows the new value already in step 7 where it should only change in step 11..?
have you got a hint for me?
Thanks!
Jeroen
CatID=INTEGER|0
ExternalName=STRING|"Task9"
ID=INTEGER|461530805
Name=STRING|"COUNT ROWS AND DIFFERENT CUSTOMERS"
Name=STRING|"Set variable ""ROWS"" with value ""0"""
varname=STRING|"ROWS"
varvalue=STRING|"0"
Name=STRING|"Set variable ""COMPARE"" with value ""{CUSTNO}"""
varname=STRING|"COMPARE"
varvalue=STRING|"{CUSTNO}"
Name=STRING|"Set variable ""COMPARE"" with value ""0"""
varvalue=STRING|"0"
Name=STRING|"Set variable ""CUST"" with value ""0"""
varname=STRING|"CUST"
varvalue=STRING|"0"
Name=STRING|"Set variable ""CUSTNO"" with value ""0"""
varname=STRING|"CUSTNO"
varvalue=STRING|"0"
Name=STRING|"Text Loop"
destvar=STRING|"CUSTNO"
line0=STRING|"1225"
line1=STRING|"1225"
line2=STRING|"1309"
line3=STRING|"1388"
line4=STRING|"1388"
line5=STRING|"2820"
line6=STRING|"2820"
linecount=STRING|"7"
sourcetext=STRING|"1"
Name=STRING|"Increment variable ""ROWS"""
incement=STRING|"1"
vaiable=STRING|"ROWS"
Name=STRING|"Show ""ROWS: {ROWS}"""
msg0=STRING|"ROWS: {ROWS}"
msg1=STRING|"CUSTNO: {CUSTNO}"
msg2=STRING|"COMPARE: {COMPARE}"
msg3=STRING|"CUST: {CUST}"
msgcount=STRING|"4"
operator=STRING|"1"
type=STRING|"1"
value1=STRING|"{CUSTNO}"
value2=STRING|"{COMPARE}"
Name=STRING|"Increment variable ""CUST"""
incement=STRING|"1"
vaiable=STRING|"CUST"
Re: counting rows and unique numbers
You should turn ON "Expand variable now" parameter
If it is OFF then you set the value "{CustNo}" (not a number)
in step #8 RoboTask expands the expression "{COMPARE}" and gets "{CustNo}". Expands again and gets the same number as in CustNo variable
If it is ON then RoboTask expand the expression first and then assigns the result into variable.
Also, pay attention that this algorithm works only for sorted lists
jeroen123
Post by jeroen123 »
Thanks!, this works :D
