Nested File Loops - Continue is confused
photofrog
Post by photofrog »
I may have found an issue. Please see schedule image at http://bit.ly/1vnCvjo
The Continue command appears to be continuing to the "inner" File Loop instead of the "outer" File Loop. But the "inner" loop has already been exited with a Break.
Can you verify if this is actually an issue?
Thank you.
David
Re: Nested File Loops - Continue is confused
This is a real bug. Thank you for the report.
Install this patch please. This have to fix the problem
photofrog
Post by photofrog »
It works now!
Thank you so much for the quick response.
David
