Helo, I'm trying to generate a random number between 0 and X
where X could be any number stored in a variable, but when I use Evaluate and the system variable RandomValue in something like this:
x=6
{RandomValue({X})}
or this:
{RandomValue(5+1)}
I always get the default behavior of 0 to 1000, is this a bug? Is there a workaround?
Thank you!
randomvalue
Re: randomvalue
Try the example below.
It works
If you use incorrect or non-integer value in parameter this variable use default parameter (1000)
It works
CatID=INTEGER|1778412004
ExternalName=STRING|"Task120"
ID=INTEGER|16042901
Name=STRING|"Random value"
Name=STRING|"//set value at step 1"
comment=STRING|"set value at step 1"
Name=STRING|"Set variable ""NUM"" with value ""6"""
varname=STRING|"NUM"
varvalue=STRING|"6"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"10"
defh=STRING|"1"
defw=STRING|"1"
duration=STRING|"5"
height=STRING|"76"
icon=STRING|"3"
kind=STRING|"0"
message=STRING|"{RandomValue({num})}"
position=STRING|"3"
title=STRING|"RandomValue"
width=STRING|"330"
Re: randomvalue
Thank you, what I was trying to do was:
{RandomValue({num})}+1
But wasn't working. This works:
({RandomValue({num})})+1
Re: randomvalue
Use "JS Evaluate" action for simple arithmetic operations.
This actions designed for this.
Re: randomvalue
Also you can save the value into variable and use "Increment Variable" action
