where is the task data saved?
bedrock
Post by bedrock »
Hi, I just wonder where the task data saved. After I uninstalled Robotask and reinstall, The task data are still there. So i would like to know how to remove the data completely.
thanks in advance :)
Uninstall program don't delete your tasks, because it is user data which can be important. Usually tasks is placed into \Documents and Settings\<User_Name>\Local Settings\Application Data\RoboTask\Tasks folder on your system disk.
You can change the task's folder by using menu Options | Settings ....
