Webpage load check
ricardo
Webpage load check
Post by ricardo »
good day.
i need robotask do a check in my asp page was loaded without errors
the task its basicly do: open the page> extract font source> find "copyright" word> alert "ok" if found it/alert "fail" if not found
my main problem its to extract the font source from the web page
robotask can do it?
Re: Webpage load check
There is Web Page information action for this.
You can retrieve HTML source code or text only from specified page.
