Folder count
dbortunk
Folder count
Post by dbortunk »
I have a file monitor task setup on a base folder with watch subfolders. Is there a way to set the watch subfolder to be only 1 subfolder deep? I dont want it to process past the base of the first subfolders meaning
Root
subfolder
subsubfolder
subfolder
subfolder
the file monitor porcess is watching Root and subfolders but i dont want it to watch or process files from subsubfolders. Is there any way to achieve this? If not is there a way to count folder in the path?
dbortunk
Re: Folder count
Post by dbortunk »
Is this not possible?
Re: Folder count
File monitor trigger allows to monitor listed folders or folders with all sub-folders.
If you want to use only one level you should analyze the list of changed files in the task.
Another way:
You can specify necessary folders without sub-folders in File Monitor trigger. This trigger can monitor several folders simultaneously.
