Move files up in subdirectory
rice1973
Post by rice1973 »
Hello Oleg,
I need to move the files up one subdirectory.
The working task i now have moves it up 2 subdirectories. What do i have to change to moce the files up one subdirectory?
See task below;
CatID=INTEGER|1981091247
ExternalName=STRING|"Task20"
ID=INTEGER|832014844
Name=STRING|"1.6 alles naar rootmap serienummer verplaatsen"
Name=STRING|"Create local variable ""ROOTFOLDER"" with value """""
varname=STRING|"ROOTFOLDER"
Name=STRING|"Create local variable ""CURRENTFOLDER"" with value """""
varname=STRING|"CURRENTFOLDER"
Name=STRING|"Create local variable ""CURRENTFILE"" with value """""
varname=STRING|"CURRENTFILE"
Name=STRING|"File Loop"
date1=STRING|"20130118"
date2=STRING|"20130118"
destvar=STRING|"ROOTFOLDER"
DuringMinutes=STRING|"1"
file0=STRING|"C:\3dmaptemp\360\???.??.???"
searchkind=STRING|"1"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
date1=STRING|"20130117"
date2=STRING|"20130117"
destvar=STRING|"CURRENTFOLDER"
file0=STRING|"{rootfolder}\*.*"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
destvar=STRING|"CURRENTFILE"
file0=STRING|"{currentfolder}\*.*"
searchkind=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"{rootfolder}"
f_count=STRING|"1"
file0=STRING|"{CurrentFile}"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
type=STRING|"1"
value1=STRING|"{FilesCount({currentfolder})}"
value2=STRING|"0"
Name=STRING|"Remove Nonempty Folder ({currentfolder})"
deletefolder=STRING|"1"
folder=STRING|"{currentfolder}"
Robotask rules! :)
Re: Move files up in subdirectory
Try this task
CatID=INTEGER|317955339
ExternalName=STRING|"Task944"
Name=STRING|"1.6 alles naar rootmap serienummer verplaatsen (v2)"
file0=STRING|"c:\3dmaptemp\360\???.??.???"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Change Folder ({rootfolder})"
folder=STRING|"{rootfolder}"
Enabled=INTEGER|0
Name=STRING|"Show ""{GetCurrentFolder}"""
msg0=STRING|"{GetCurrentFolder}"
msg1=STRING|"{rootfolder}"
msg2=STRING|"{ExtractFileName({currentfolder})}"
msgcount=STRING|"3"
destdir=STRING|"{ExtractFilePath({rootfolder})}"
f_count=STRING|"1"
file0=STRING|"{CURRENTFOLDER}"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
Pay attention that you should to move the folder to parent folder of {RootFolder} (not to {RootFolder})
rice1973
Post by rice1973 »
Fixed!
Robotask rules! :)
