Pad String
rjkantor
Pad String
Post by rjkantor »
I am looking for a pad string method to allow me to pad a string that I extract so that I can have aligned columns of output in my email.
Any ideas on how to accomplish the pad method? or does this need to be added to robotask?
Thank you,
Rob
Re: Pad String
See this example:
CatID=INTEGER|933306365
ExternalName=STRING|"Task431"
ID=INTEGER|2085317457
Name=STRING|"PAD example"
Name=STRING|"Create local variable ""STR"" with value ""Hello World!"""
varname=STRING|"STR"
varvalue=STRING|"Hello World!"
Name=STRING|"Set variable ""STR"" with value ""{str}{char}"""
varvalue=STRING|"{str}{char}"
Name=STRING|"Show ""Final string """
[Actions\Action13\Params]
msg0=STRING|"Final string "
msg1=STRING|"""{str}"""
msgcount=STRING|"2"
Name=STRING|"Create local variable ""CHAR"" with value ""*"""
varname=STRING|"CHAR"
varvalue=STRING|"*"
Name=STRING|"Create local variable ""TARGETLEN"" with value ""30"""
varname=STRING|"TARGETLEN"
varvalue=STRING|"30"
Name=STRING|"Create local variable ""TOLEFT"" with value ""true"""
varname=STRING|"TOLEFT"
varvalue=STRING|"true"
Name=STRING|"Show ""Source string """
msg0=STRING|"Source string "
msgcount=STRING|"2"
Name=STRING|"While loop"
operator=STRING|"5"
type=STRING|"1"
value1=STRING|"{StrLength({str})}"
value2=STRING|"{TargetLen}"
value1=STRING|"{toLeft}"
Name=STRING|"Set variable ""STR"" with value ""{char}{str}"""
varvalue=STRING|"{char}{str}"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
You can implement similar algorithm in BASIC script
