Move folder and files to folder in same folder
rice1973
Post by rice1973 »
Hi Oleg,
I cannot get it fixed to build a move task.
Folderstructure is like below;
I want to move the folders orbitvu and orbitvu12_basic and the file 18765-266.10.300.html into the folder 18765-266.10.300
The name of the folder 18765-266.10.300 is variable and also the name of the 18765-266.10.300.html file.
The name of the parent folder is 3dmap.
I
Robotask rules! :)
Re: Move folder and files to folder in same folder
See my example:
CatID=INTEGER|1416408852
ExternalName=STRING|"Task117"
ID=INTEGER|620029868
Name=STRING|"Rename Files and folders"
Name=STRING|"Create local variable ""FOLDER"" with value ""18765-266.10.300"""
varname=STRING|"FOLDER"
varvalue=STRING|"18765-266.10.300"
Name=STRING|"Change Folder (C:\Temp\test)"
folder=STRING|"C:\Temp\test"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"{folder}"
f_count=STRING|"3"
file0=STRING|"{folder}.html"
file1=STRING|"orbitvu"
file2=STRING|"orbitvu12_basic"
hidden=STRING|"1"
ifexists=STRING|"0"
move=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
rice1973
Post by rice1973 »
The foldername 18765-266.10.300 also has to be variable.
So the task must "read" it from the foldername.
Now you set is as a "solid" valeu.
Robotask rules! :)
rice1973
Post by rice1973 »
Hi Oleg,
I modified the task, still does not work. Can you look?
CatID=INTEGER|1981091247
Name=STRING|"Rename Files and folders (imported)"
Name=STRING|"Create local variable ""FOLDER"" with value """""
Name=STRING|"File Loop"
date1=STRING|"20130118"
date2=STRING|"20130118"
destvar=STRING|"FOLDER"
DuringMinutes=STRING|"1"
file0=STRING|"C:\3dmap\360\?????-???.??.???"
searchkind=STRING|"1"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Change Folder (C:\3dmap)"
folder=STRING|"C:\3dmap"
f_count=STRING|"3"
file1=STRING|"orbitvu12"
hidden=STRING|"1"
ifexists=STRING|"0"
move=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
Robotask rules! :)
I think that you should to move step#3 (change folder) out of the loop.
It seem this example can help you:
CatID=INTEGER|933306365
ExternalName=STRING|"Task505"
Name=STRING|"Change Folder (C:\3dmap\360\)"
folder=STRING|"C:\3dmap\360\"
file0=STRING|"?????-???.??.???"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
f_count=STRING|"3"
hidden=STRING|"1"
ifexists=STRING|"0"
move=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
rice1973
Post by rice1973 »
Solved!
Robotask rules! :)
