Scheduler
hs1972
Scheduler
Post by hs1972 »
How would you set the scheduler up so it triggered every last Saturday in the month?
Many thanks.
Re: Scheduler
See example below.
CatID=INTEGER|1416408852
ExternalName=STRING|"Task119"
ID=INTEGER|161569533
Name=STRING|"Last Saturday of the Month"
type=STRING|"1"
value1=STRING|"{DayOfWeekNo}"
value2=STRING|"7"
operator=STRING|"1"
type=STRING|"1"
value1=STRING|"{MonthIncDays(7)}"
value2=STRING|"{MonthNo}"
Name=STRING|"Show ""Place here your own code"""
msg0=STRING|"Place here your own code"
UnigueID=INTEGER|16445953
periodicity=STRING|"2"
periodparameter=STRING|"00000000000000000000011111111110"
startdate=STRING|"41820"
time0=STRING|"36000000"
timecount=STRING|"1"
wakeup=STRING|"0"
You should schedule the task on "Every month" basis at 22-31 days.
in the task you should check the day.
The condition "The Last Saturday of the month" requires two conditions:
- this day must be Saturday: {DayOfWeekNo} = 7
- if you calculate the month 7 days later it will be another month: {MonthIncDays(7)} <> {MonthNo}
hs1972
Re: Scheduler
Post by hs1972 »
Many thanks Oleg.
