Task tree
hs1972
Task tree
Post by hs1972 »
On start up I get an error message in the lower panel saying 'can't load task tree'
I'm not sure why this is or what I've done to cause it. I can't remember doing anything.
Does anyone have any ideas why this is happening?
thanks
Re: Task tree
This is not an error. It is warning only.
It seems you have an empty task tree. So the file of tree is absent.
hs1972
Re: Task tree
Post by hs1972 »
That's a relief! Many thanks Oleg for your ongoing support whilst I'm getting used to the software. It's very much appreciated.
