How to write a text file with SQL Query
misery
Post by misery »
Hi Oleg,
I've created a table with MySQL called name, and this table has many rows but only 3 fields (name, coordinate1, coordinate2) each with their own data. I'm trying to Query this table (name) so that any results will be written to a text file. I'm not sure if Dataset Loop is needed for this or not.
I've successfully created an SQL Query with Connection String:
Provider=MSDASQL.1;Persist Security Info=False;Extended Properties="DSN=Main;DESCRIPTION=Main Coordinates List;SERVER=localhost;UID=root;DATABASE=names;PORT=3306"
and in the "SQL Query" field I have:
SELECT name, ( 6371 * acos( cos( radians(45.0843184) ) * cos( radians( coordinate1 ) )
* cos( radians( coordinate2 ) - radians(-64.398319) ) + sin( radians(45.0843184) ) * sin(radians(coordinate1)) ) ) AS distance
FROM name
HAVING distance < 25
ORDER BY distance
LIMIT 0 , 20;
The task executes successfully but I have no idea how to write all the results to a text file. Please help!
Thank you
Re: How to write a text file with SQL Query
You should use "Dataset loop" for SELECT query.
You can create the text line by line in the loop and then save it into a file.
see the example below:
CatID=INTEGER|1416408852
ExternalName=STRING|"Task120"
ID=INTEGER|2054445370
Name=STRING|"save the text from SQL query"
Name=STRING|"Create local variable ""FILENAME"" with value ""{TempDir}\sqltext.txt"""
varname=STRING|"FILENAME"
varvalue=STRING|"{TempDir}\sqltext.txt"
Name=STRING|"Create local variable ""ROW"" with value """""
varname=STRING|"ROW"
Name=STRING|"Create local variable ""TXT"" with value """""
varname=STRING|"TXT"
Name=STRING|"Dataset Loop"
commatext=STRING|"0"
connectionstring=STRING|"Provider=MSDASQL.1;Persist Security Info=False;Extended Properties=""DSN=Main;DESCRIPTION=Main Coordinates List;SERVER=localhost;UID=root;DATABASE=names;PORT=3306"""
override=STRING|"0"
password=STRING|"1928819338208742010719083"
sql=STRING|"""SELECT name, ( 6371 * acos( cos( radians(45.0843184) ) * cos( radians( coordinate1 ) ) "",""* cos( radians( coordinate2 ) - radians(-64.398319) ) + sin( radians(45.0843184) ) * sin(radians(coordinate1)) ) ) AS distance "",""FROM name"",""HAVING distance < 25 "",""ORDER BY distance "",""LIMIT 0 , 20;"""
timeout=STRING|"60"
var2=STRING|"ROW"
withmemo=STRING|"0"
Name=STRING|"Set variable ""TXT"" with value ""{TXT}name={row(0)}; distance={row(1)}{eol}"""
varvalue=STRING|"{TXT}name={row(0)}; distance={row(1)}{eol}"
Name=STRING|"Create text file {filename}"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{filename}"
line0=STRING|"{txt}"
suppress=STRING|"0"
misery
Post by misery »
That worked perfectly Oleg! Thank you
